Vpn service that works with flex smart link?
Take a look at a VPN service called Tailscale. I use it for SmartSDR as well as linking via node red on my rapsberry Pi. It is a free service for non-commercial use.
Bob, KN4HH
Does that then connect to your home router? I guess how did you get your FLex radio on the VPN.
Hi Brad, with SmartLink you don't need a VPN to connect SmartSDR to your radio remotely. Are you looking for basic connectivity to your radio, or do you have something specific that you are trying to do that requires a VPN?
Interesting to hear that Tailscale works, they claim to be using Wireshark as a base, and that is supposedly not supporting layer2, i.e. no discovery packets.
For us CW-fans forced to stick with 2.4.10 there is NO SSDR working remote! So I am curerntly using a simple RPi with SoftEther VPN and it has been running for a number of years!
My current internet is carrier grade NAT so no public ip address that. Basically using cell internet
Ah, OK. Well, when I operate remotely, I use my cell phone as a hotspot. I connect to my radio using SmartLink (not VPN). I also have an older laptop in the shack that I VPN into (SoftEther) to connect my TeensyMaestro to the radio. I use TeamViewer to control my rotator and to monitor/operate my amp and tuner.
I think you are generally better off connecting SmartSDR using SmartLink to get better latency numbers. Everything else can be on the VPN and/or a facility like TeamViewer.
All of that being said... one thing you might want to do is to put in a helpdesk ticket. The Flex folks have helped a lot of people with a really diverse set of network equipment and ISP issues. I am guessing that they can get you working without resorting to your cell phone.
Hi Pat, I don't have a Maestro. I have my own, homebrew "TeensyMaestro". If I have good cell service, the whole thing works great (SmartSDR using SmartLink, TeensyMaestro using SoftEther VPN, everything else via TeamViewer). If I have crummy cell service, it works pretty well, but does drop off the network occasionally and often has outrageous latency.
Since my TeensyMaestro does not pass panadapter or audio data, it is solid as a rock, even under poor connectivity conditions. SmartSDR or a real Maestro do everything, and have a much heavier load to bear than my little gizmo, so they are more sensitive to network quality.
I would say give it a try, you might be surprised at how well it works. I would also say not to get your hopes too high; a cell phone hotspot for high speed real-time data transfer is a compromise at best.
Here is a diagram of my current remote setup:
Note that if I were ever to be in a place with available WiFi (hasn't happened yet...) then I would just use the WiFi in the laptop, not the phone. With this arrangement, I can run my logger (N3FJP ACLog) from either PC.
Sorry, I need to clarify. I use Tailscale in conjunction with FRStack and node red to control my flex interfaces (tuner, amplifier, power, etc.). SmartSDR does not require the use of a vpn.
Bob, KN4HH
Tailscale is a great tool, but it is not a VPN - too much to explain here. It is more of a point to point tunnel, not point to network tunnel. You'll want to have a close look at it. https://tailscale.com/
If you want a VPN to replace SmartLink, the easiest and most documented is SoftEther (you can search for it in the community). We used it before we released SmartLink.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
