No Audio Mute on TX LOUD feed back
Steve Blankinship AG4SO
in Maestro
Upgraded maestro to 2.7.6 now audio will not mute when I tx. volume at 0, only one slice, TX generates a LOUD squeal unless I unplug the FHM-3 mic. This did not happen before the upgrade. Mic is loaded in the mic profile. PTT does not appear to be stuck. So what am I missing folks. Thanks Steve AG4SO
Hi Steve, did you check to be sure that you don't have the Monitor engaged? That will cause the symptom that you are seeing.
Thanks Len some times the obvious is the hardest to see.
73 Steve
Yep, always seems to be the way... Glad that is all it was.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
