No Audio Mute on TX LOUD feed back
Upgraded maestro to 2.7.6 now audio will not mute when I tx. volume at 0, only one slice, TX generates a LOUD squeal unless I unplug the FHM-3 mic. This did not happen before the upgrade. Mic is loaded in the mic profile. PTT does not appear to be stuck. So what am I missing folks. Thanks Steve AG4SO
    Answer ✓
    Hi Steve, did you check to be sure that you don't have the Monitor engaged? That will cause the symptom that you are seeing.
  • Steve Blankinship AG4SO
    Thanks Len some times the obvious is the hardest to see.
    73 Steve
    Yep, always seems to be the way... Glad that is all it was.
