Distorted FT8
Setting are:
WSJT-X TV level at -6 or lower.
DAX at 55 for about 80 watts out.
The attached picture is what I see. I see that distortion all the way down to around 5 - 10 watts out.
Anyone have any thoughts before I open a ticket?
Steve N4GXX
I cannot open your attachment.
Make sure the peak level indicator is not going red (above zero). It should be yellow at highest. Set WSJT-X power slider all the way up and set DAX TX to 48. That will set proper output level.
You may see the "birdies" as you described them on the panadapter during TX but unless you are using full duplex and monitoring your signal on an actual receiver what you see may not be going out.
As far as your friend, how strong are you to him? If around +25 then you can potentially be overloading his front end and causing him to see stuff that might not be an issue.
If using a solid state amp you can expect the 3rd order IMD to only be down about 30 to 35dB at best.
73 Dave wo2x
A: He had me on the back side of his 6 Mtr beam at the time. B: He put 20dB of attenuation in line with no change. I see the same thing on my panadapter at the same spacing. I at around the -6dB mark on my input (the yellow bar). I am also seeing trash on a dead carrier into a dummy load.0
Please handle this via a support ticket if you are not doing so already. Thanks
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
