PGXL log files
I'm finding log files in the [user]/AppData/Roaming/4O3A Signature/Power Genius folder that are quickly taking up disk space. One 1441 KB file is generated each hour. They contain information that is updated once per second like the following snapshot of 2 seconds worth of a file:
2021-06-30T17:00:00.0159299-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.1783949-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.3389553-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.4994423-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.6594536-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.8222873-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:00.9835244-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.1445489-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.3045206-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.4668894-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.6286985-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.7894000-04:00;0;1.07;0.0;36.7;36.4;0.0;False
2021-06-30T17:00:01.9499502-04:00;0;1.07;0.0;36.7;36.4;0.0;False
Has anyone seen this? Is there something wrong with the install? I've had the PGXL operating for about 1 week and the files take up close to 70 MB of disk space.
I checked my folder and it is 57 MB. But that is only for the last 2 days. I have been very active since April 4, 2021. Maybe only there is a setting to only capture the last few days?
Hi Les
Those files are used to make the Graph and are normal operations.
It should grow to about 46M in size. You won't see it grow much as there as rules involved to limited the size.
Mike,
Apparently mine is set to 1.5 GB per file!
73, Bill
That is 1.5 Meg (not Gig).
Check on the properties for that folder and see how big it is.
Correct. My error! 1.5 MB per file. Here are the folder properties:
Bill
66M looks about right. It is the program working as designed.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
