Flex 6500 multi-flex V3 software and WSJTX
I have 2 questions re: the flex V3 software, using WSJTX, and FT8, I hope that you can enlighten me.
1. Will the V3 software allow two users to hookup to the flex radio (one remote on local user),on the same band? In this case 6M.
2. will it also allow two users to transmit, not at the same time, but one after the other, with the other in the monitoring mode?
Why? we would like to setup a 1.5KW 6m pa and our 6500 flex and hopefully both working 6M DX concurrently on 6M.
de Rick, W6SR
Hi Rick, yes to question 1 and "sort of" on question 2. The 6500 has one Spectral Capture Unit (SCU), so that means both have to share a receiving antenna. So while one transmits, the other can't hear. So if this is for casual operation with each station taking turns (and a way to coordinate with one another), it may be perfectly adequate. If this is a contest situation with one station running a freq and the other hunting multipliers, it could also work, but will still require good coordination and is limited by the single SCU. If this is for two contesters to operate independently, then I don't think you would be happy with this setup. What really does not work, is monitoring the other station by listening to the radio.
If you have a 6600 or 6700 with two SCUs, then by careful separation of antennas, one can listen while the other transmits, especially if it is on a different band (same band may or may not work depending on antenna proximity and power levels). There is still just one transmitter, so coordination is necessary in this case as well.
[{"insert":"Thanks I appreciate answer/comments \n It sounds like we can make this work, making serial contacts on the same band while both of us share viewing and control the same slice. Again Thanks de Rick, W6SR\n"}]0
Cool, I am glad that will work! Since you will be using MultiFlex, each station will only see their own slice, not the other's. That is not a problem as you both just put your slice on the same frequency.
One outside-the-box thought... My homebrew TeensyMaestro will connect to a radio with two clients already connected using MultiFlex. One side shows one person's slice and the other side shows the other person's slice. The TM can control each slice independently, or lock the two together so that the frequency of one slice is tracked by the other slice, and vice-versa. With a pair of these boxes you would always know where the other guy is tuned, or both be able to move both radios simultaneously.
I haven't played with Node-Red yet, but I would guess that the same thing could be accomplished with the Node-Red software flows on a computer or a Raspberry Pi.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
