2m and 70cm Transverter for 6700 for QO-100 SAT operations
Wolfgang
Wolfgang Member ✭✭
Hello All
I'm looking for a 2m and 70cm Transverter solution for my Flex 6700 in order to use it with the QO-100 Transverter from PE1CMO.
TX for the QO-100 SAT on 70cm (431.500 - 431.995)
RX for the QO-100 SAT on 2m (144.500 - 145.000)
Any idea?
Best 73 de HB9RYZ
Wolfgang
  • Bill AB7AA
    Bill AB7AA Member ✭✭✭
    Hi Wolfgang,
    I use the LDPA amp and Q5 L432-28 transverter with wide front end filter (432-450). They are capable of full duplex operation required for some satellite operations with the Q5 Dips switch and together function well. That being said, I do not use mine yet for satellite work so I cannot comment on its performance in that capacity. I wish that we had a QO-100 SAT equivalent sat over North America and if we did I'd leap on it in a heartbeat. I can't hit QO-100 from southern Arizona.
    So, I'm interested to hear from others that may have used this combination for satellite or weak signal ops.
    Bill AB7AA
  • Wolfgang
    Wolfgang Member ✭✭
    Hello Bill
    Thanks for your comments.
    I'm in contact with Q5 Signal and Kuhne to get some more details about their transverters.
    Best 73 de HB9RYZ
    Wolfgang
  • on5po
    on5po Member ✭✭
    Hello everyone ,
    I'm looking for help, detailed explanations,
    I have a flex 6700 and want to do a show with "QO-100".
    to avoid shopping for nothing,
    my first question do we need another rx / tx.
    I understand that the 2 meter part of my flex 6700 should be enough plus a kid tranverter up to the antenna.
    thank you for helping me
    73 on5po, Janny
