Boot failure?
I have raised a helpline ticket for the following, but thought I might put this to anyone interested:-
6600M, iMac Pro, and SmartSDR for Mac smart control.
For weeks, this combo has worked very well for me. Yesterday, when I turned on it my usual way, I got the thrice-blinking led, and no boot-up. I shut down, disconnected the ethernet cable, re-booted and all was well. i.e. the free-standing rig worked (thank goodness for the "Maestro" front panel built in). I found that when I then connected up the iMac ethernet cable, I was then able to then move over to SmartControl quite happily. Weird or what? I have checked alternative cables, fully pulled power, waited the prescribed minutes of wait-time before re-connect, etc, etc, etc.... I get the same result. Closing down and the restarting in my preferred way, and back came the blinking reds. So the only way I can get SmartSDR Smart control is to disconnect iMac, boot up the 6600M, then hook up the ethernet cable after I have got to the screen for "RUN/SMART CONTROL" and then select accordingly.
I noticed that I did not hear the start-up fan-speed-test during attempt at boot-up which resulted in red-leds, whereas when I booted without the ethernet cable attached, the fan-speed-test did occur as you would normally expect.
Has anyone else had a similar problem?
Cheers. Mike. G4GWH
Possible Persistence Database error. Export your current settings and do a factory reset.
Thanks Eric. I tried factory reset, but the same problem exists. Just have to get used to connecting ethernet cable after main rig boot-up, until Flex can offer a solution.
Do you perhaps have an IP address collision? The "M" section and the radio both need an IP address, and if either fails, you will get strange things happening. (6600M / SSDR Mac here).
OK Ted. I have checked there is Ethernet IP for the front panel, and there is also IP address for the radio itself. My iMac Pro says it is using DHCP, so I think that is ok.
Thanks. Mike.
Re. This issue……..
I now have a help desk response from FlexRadio in Austin. Hopefully it may just be a matter of swapping the SD card for a new one.
I will update this report later, when I have “done the deed”.
Mike G4GWH.
Problem solved! Tim from Flex very kindly responded, and instructed a replacement 6600M.
I am happy to report the replacement works 100%
Well done FlaxRadio. Superb after-sales service!!
Mike. G4GWH
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
