Using a mechanical Bug or SK with a Maestro?
Best Answers
A straight key with the Maestro is no problem. As a bug is also a make/break key, it should work as well. However, you need to go into a menu to switch between iambic keying and a straight key.
If it’s a real mechanical bug, it plugs in and is seen as a straight key.
Thanks to both for the quick response0
Thanks, look forward to ordering but, if I am reading the website correctly, maestros are not available until Fall.0
If I remember correctly, there is a slight bug when using a straight key with the Maestro vs the radio.
It will be in the settings and you may have to do a Reverse on the Maestro if I remember correctly. (it has been a while).
But, yes, it does work.
Thanks for the advise, it helps me a lot.0
I switch back and forth from a SK and paddle all the time with my Maestro. There is an iambic “Enable/Disable” button in the CW menu. It’s easy to get to and works fine. No problem.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
