I have no indicattion 0f power out on the display
Jim.W4ATK
Member ✭
the ATU works well but no indication of power out.
Hi Jim... when you say you have no indication, do you mean that you can't see the power output meter or that there's no movement on the meter?
If the latter, have you checked what level your power output is set to? There's one setting for TUNE (usually 10W or less) and another for MAX (I think it is)
Also, if no power out when in Tune, put the slice into the the CW mode and check the CW pitch is set for 600hz.
Alan. WA9WUD
thanks for the reply. By clicking TUNE i do indicate power out. My bad.0
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
