I have no indicattion 0f power out on the display
the ATU works well but no indication of power out.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Jim... when you say you have no indication, do you mean that you can't see the power output meter or that there's no movement on the meter?
    If the latter, have you checked what level your power output is set to? There's one setting for TUNE (usually 10W or less) and another for MAX (I think it is)
  • Alan
    Alan Member ✭✭✭✭
    Also, if no power out when in Tune, put the slice into the the CW mode and check the CW pitch is set for 600hz.
    Alan. WA9WUD
  • Jim.W4ATK
    Jim.W4ATK Member
    thanks for the reply. By clicking TUNE i do indicate power out. My bad.
