3 red flashes - My Flex Radio doesn't boot up
When I start up the readio I get the normal green flashed then it turns into 3 red flashing lights. I installed version 3.2.39. Thats when I noticed this problem. Maybe it didnt install propoerly? Hopefully it can be reversed. Thanks
  • Hiram Vazquez
    Hiram Vazquez Member ✭✭
    i just realized i put this in the wrong forum?
    The first thing to try is a factory reset. Check the manual for your radio on how to do it. If you still have the problem after a reset, you should submit a help desk ticket.
    I created a support ticket for this.
This discussion has been closed.
