I have no indicattion 0f power out on the display
Jim.W4ATK
Member ✭
the ATU works well but no indication of power out.
Hi Jim... when you say you have no indication, do you mean that you can't see the power output meter or that there's no movement on the meter?
If the latter, have you checked what level your power output is set to? There's one setting for TUNE (usually 10W or less) and another for MAX (I think it is)
Also, if no power out when in Tune, put the slice into the the CW mode and check the CW pitch is set for 600hz.
Alan. WA9WUD
thanks for the reply. By clicking TUNE i do indicate power out. My bad.0
- 390 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
