Flex-6600 power loss, how to auto start Flex-6600 when power get back?
SorenB
Member ✭
Hi, when You get a power fail and drop the main power. Is it possible that the Flex-6600 startup again automaticly?
Regards
/Soren
Regards
/Soren
Best Answers
Enable the "Remote" on/off.
Then, install a jumper or relay on the remote, on RCA back connection, to switch the Flex On. Leave it in the on position.
Alan. WA9WUD
Remote power on/of RCA connection question. I understand the connection is shorted (connect the center pin to the outer shell) to turn on the Flex. If the short is broken, will the Flex turn off? Turn off as if you pressed the power button on the front of the radio?
Yes. The operation of the RCA Remote Connector is described in the Hardware reference manual.
2
Thank You B)0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
