iOS iPhone app not seeing radio on via Smartlink in V3.2.37 or .39
Smartlink has been working at my QTH for many years using my iPhone app on 6500 with V2 software. And it was working when I got my new 6700 with V3.2.31/34. But has not been connecting to the 6700 since installing .37/39. In the iOS app Smartlink is connected to my credentials as it is on my PC so I don't know what I'm doing wrong??
Thank you, Dennis, k0eoo
Also having trouble connecting except I have a 6300. Port is showing as -1 in the radio info. I believe it should be 21000 or 22000. I can't seem to be able to change it in the app. Was not working on .37 and have upgraded to .39 with same results.0
Probably best to submit a helpdesk ticket. Your issue will be solved waaay faster by Flex than by all of us taking a swing at it...
I cannot connect either by the Smart IOS app on iPhone or iPad. Just keeps bringing me back to the not connected screen "tap here to connect"
Did you try rebooting the iOS device. I had too do so to regain functionality.
I have attached a photo of what my SmartLink setup looks like...this works for me...make sure your port forwarding is correct.
I had a issue like describe...I found I had a port forwarding issue...hope this helps.
73, Ronald
Rebooting the iPad did it . . . Thanks
@Ron,
Thanks Ron for sending the SmartLink picture showing the setup. It took me a while to figure out how get to that window but when I did I realized my radio wasn't logged onto SmartLink! Once I did that I was able to get the SmartLink connection on my iPhone!
All those who had the same problem that might be your solution as well...
Cheers, Dennis, k0eoo
When you get a -1 for ports it means that the ports are not defined correctly.
The 'quick' fix is to reboot all devices. If you want to understand what is going on, you will need to log into your router and make sure that the forwarded ports reference the actual IP address of the radio.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
