Flex USB port to Ciro Mazzoni ATU controller
Ed Brenner
I can not get the ATU controller to work in either full or semi auto mode . In manual it will select and tune. I am using the cable they sell for the Flex.
It sees the cable but doesn't appear to output frequency change as I tune the radio.
Settings are Cat, TX antenna, Ant2, Auto Report Enabled, Speed :9600 Bits 8 Parity none , stop bits 1
Flow control none.
Missing something ?
Thanks for any help
ED KM4HPN
Have you tried using "Specific Slice" vs. "TX Antenna"?
Struggling with the same problem myself. Ticket in to Ciro. Already verified ATU2 firmware is on 4.06 which is required due to a flex cat change (per Ciro)0
I have the same issue. How did you solve yours?
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
