Maestro A Panadapter freeeze after 3.2.39 update
The 3.2.39 update went fine and Smartlink connection is back. However the Panadapter display freezes
I have restarted many times with the same result. RX and TX functions do work.
Bob, KN4HH
Welcome!
  • Member ✭✭✭
    Additional information:
    After I connect to my wifi hotspot, no radios are available. I have to log out and log back in to establish a smartlink connection. I have to do this each time I power up the Maestro.
    Bob, KN4HH
  • Member ✭✭✭
    Yet more information:
    I solved the Smartlink log in problem by going to SmartSDR and unregistering and reregistering.
    Also, the Pan Adapter freeze only occurs when in a Smartlink connection. If I connect to the radio within my network, the display is normal.
    Bob, KN4HH
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited June 2021
    I have moved this to a support ticket.
This discussion has been closed.
