"Snap to tune step" does not persist?...
The "snap to tune step" feature found in Settings/Radio Setup/RX does not persist, at least for me. I continually have to go back in and put it back to "enabled."
Is it just me, or is this a thing?
Thanks all!
Hi Mike... when you say it doesn't persist, is it staying 'on' during each session with the radio then is turned off when you come back, or are you having to reset it even during constant use of the radio?
(I'm wondering if this setting is part of the 'autosave settings' feature that was introduced in v2.5 and something you are doing is causing SSDR to either reset the setting or saving the wrong value).
Hi Don...most of the first part of what you said. I have to turn it on during each session. It stays on throughout the session, but when I turn the radio off, I have to go in and enable it again.
Whatever is causing it, I'm sure it's all my fault! (My wife likes to say that a lot!)
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
