"Snap to tune step" does not persist?...
The "snap to tune step" feature found in Settings/Radio Setup/RX does not persist, at least for me. I continually have to go back in and put it back to "enabled."
Is it just me, or is this a thing?
Thanks all!
Hi Mike... when you say it doesn't persist, is it staying 'on' during each session with the radio then is turned off when you come back, or are you having to reset it even during constant use of the radio?
(I'm wondering if this setting is part of the 'autosave settings' feature that was introduced in v2.5 and something you are doing is causing SSDR to either reset the setting or saving the wrong value).
Hi Don...most of the first part of what you said. I have to turn it on during each session. It stays on throughout the session, but when I turn the radio off, I have to go in and enable it again.
Whatever is causing it, I'm sure it's all my fault! (My wife likes to say that a lot!)
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
