skimmer - spot out of band or on another frequency
hi all, have if you can help me
I have cwskimmer and slicemaster set up apparently fine.
but I have a problem that the spot graphs them in the slice as a mirror or duplicates (attached image)
this second spot shows me out of band or even above 14065khz
Can you help me see what am I doing wrong?
Thank you so much
Javi LU5FF
What sampling rate do you have selected in Slicemaster? Is it 9600 which is what you have for CWS and DAX? If it is, what happens if you change SM, CWS and DAX all to 4800?
Hi Erik.. yes all 96khz..
in 48 khz it seems that this does not happen
Hi Javi, yes many people say same: 48 khz is ok, 96 khz is not. You would think that 96 khz would only double the bandwidth and not be any problem but.........
did some tests changing from 48 to 96 khz the audio format of the dax iq in windows. seems to improve .. could this be the error?
I do not know, someone else may give an opinion here. Mine is set to 24 bit 48000 Hz Studio Quality for all channels including DAX.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
