FLDigi No Connect to Port Audio
I cannot configure FLDigi to use the DAX audio (it used to work). Once I check PortAudio, it almost immediately says that "Port Audio device not available." It is not a problem with the Privacy settings, as reported in 2018. The Dax Audio RX 1 and DAX Audio TX are hard-coded into the window but grayed out. Any ideas?
Ensure that in Windows 10 Settings - Privacy - Microphone, that you have 'Allow apps to access your microphone' set to On.
I have the same continuing problem. I have tried all of the recommended fixes, privacy etc., and it continues to happen. Have you had any luck since your post?
Thank you Eric,
Fixed m problems.
Eddie Jennings, AQJ4OC
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
