FLDigi No Connect to Port Audio
I cannot configure FLDigi to use the DAX audio (it used to work). Once I check PortAudio, it almost immediately says that "Port Audio device not available." It is not a problem with the Privacy settings, as reported in 2018. The Dax Audio RX 1 and DAX Audio TX are hard-coded into the window but grayed out. Any ideas?
  • Erik Carling EI4KF
    Ensure that in Windows 10 Settings - Privacy - Microphone, that you have 'Allow apps to access your microphone' set to On.
  • edwinhigg
    edwinhigg Member ✭✭
    I have the same continuing problem. I have tried all of the recommended fixes, privacy etc., and it continues to happen. Have you had any luck since your post?
  • Eddie Jennings
    Thank you Eric,
    Fixed m problems.
    Eddie Jennings, AQJ4OC
