How does a "Switch TX slice to slice A" API look like for injecting to Arduino?
I am in the process of adapting a MAC logger to SO2R contest operation. But it does not accept Flex CAT commands. The logger switches slices with the command "arrow up/down" and I thought I could build a MIDi controller (or foot switch) with a TENSY USB Board to inject a Flex CAT command to switch slices while pressing "arrow up/down",
Is this a "large set of Flex CAT commands" to achieve this? Anyone who has done something similar that can share some insights into this challenge 😊
Hi Kari, according to the PJRC web site the answer is "YES"!
Software
Arduino IDE + Teensyduino
Arduino's IDE software with the Teensyduino add-on is the primary programming environment for Teensy. On Windows, Linux and old Macs, Arduino is installed first and then the Teensyduino installer adds Teensy support to the Arduino IDE. On newer Macs, an all-in-one download is provided. Teensyduino includes a large collection of libraries which are tested and optimized for Teensy. Other libraries may be installed manually or by Arduino's library manager.
Hi Kari, I have done this with a Teensy 4.1, but not using CAT commands. I do it using the Flex TCP/IP API which gives you complete control of the radio. Enzo, IW7DMH wrote an Arduino library of Flex API functions that I adapted for use with the Teensy board. Here is the latest version of the library and a "shell" program to get you started. You will need to go the PJRC website and install Teensyduino as an add on to the Arduino IDE.
Which Teensy board do you have? 3.6 or 4.0 would work, but would require an ethernet board to be separately wired to the Teensy. They would also require modifications to the library. The Teensy 4.1 only requires the little ethernet jack to work with the library.
Link to the Flex API Wili:
SmartSDR TCP/IP API - SmartSDR Wiki (flexradio.com)
Good luck with this and let me know if you have any questions.
Hi Len, Thank you very much. OK I see APi:s is simpler than issuing a CAT command. Is this for MAC OS as well?
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
