DON'T REALLY UNDERSTAND
When I bring up my flex 6600 I only get the icom SDR SmartSDR v3.2.37 nothing about about smart link.
I would like to know how to set up a smart link account and go remotely.
Have you read SmartSDR User Guide Sec 9 (downloadable) addressing SmartLink?
Okay so if you have a M version of Radio SmartLink is kinda broken right now on the M control panel ONLY
If you have V3.2.37 and are running on a PC then when the radio is up and running up under the Settings Click on "Choose Radio / SmartLink setup" then that will log you out and bring you to the window that says connect or SmartLink setup, this is where you will need to set up the SmartLink account, Register the radio, Hit the LOCAL PTT or CW key, and then you set things up for your firewall there is a "V" down arrow about the middle of the screen and another Window will pop up the try to use the Automatic settings IF YOUR Router is set up automatic port forwarding by hitting the TEST button, If it fails then you will have to use the Manual settings and see what IP Ports and format needs to be setup in your router, When you get it correct then hit the TEST again and if it goes green then you should be good to go.
I think there is a Youtube that Mike or Eric made on setting this up and I know there are articles if you do a google search should pop right up.
This might see a bit much but I would give it a go, Hopefully your Router will configure itself when SmartLink asks it to.
Hi Lee, You will need to have your radio and SmartSDR set up on your local LAN with internet access to register your radio on SmartLink.
Next, click the icon to start SmartSDR. If it brings up the panel shown below, click the SmartLink Setup button. If it brings up the panadapter, click Settings, Choose Radio / SmartLink Setup... and then click the SmartLink Setup button.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
