Alc Problem
My issue with ALC was never bind resolved ticket number #43025, was promised with next update will be taken care this problem , but I think this problem was never address.
Hope I wasn't forgotten.
Thanks for reading my complain.
regard Dan VE2ZC 73'
for what use you need ALC?
Chris
Hi Chris
I use my alc with amplifier, I know I can set power output down on my rig 6400 but sometimes will like to work bare foot and have to readjust power on rig , was working fine before last two up dates and was promised the will take care of the problem .
Dan VE2ZC 72'
Hello Dan,
The support request you point to #43025 didn't mention ALC as an issue. You had an issue with an upgrade, and the suggested fix was a factory reset of your 6400. That was the last correspondence.
Can you please describe the issue you have with ALC? Also, please provide the make and model of the amplifier you are using.
Hello Dan
I'm sorry if I nixed up ticket numbers, I had a call from you about alc problem and you promised that most likely problem will be corrected with updates.
Sorry about my mistake about id number.
Dan VE2ZC
73'
Hi Dan,
Can you please describe the problem you are experiencing with ALC and which amplifier you are using?
As a general policy, we do not promise fixes in specific releases or provide timeframes for a fix. However, if there are known issues, a specific bug report, or a feature request, we may say that a future update may address the problem. There are always exceptions to that, but not very many.
Dan
I have flex 6400 and als-600 amp, My alc line was connected between rig and amp with old 3.1.12 version with out any problem , but now with upgrade to 3.2.31, now I need to disconnect alc line because once a wile I have no output from flex 6400,
Dan, you spend about 1 hour over TeamViewer with me try so solve the problem,
Thanks for trying solve this problem
Dan VE2ZC 73'
514 992 1551
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
