FRSacks not auto connecting anymore
Since the last two upgrades of FRStacks3 it no longer does an auto connects. I have to select a radio then connect. Even when auto connect is selected, it still will not auto connect. In the past it would do the auto connect reliably. Another issue I noticed is that I cannot export configuration setting to a file. Any one else seeing these issues.
Hi Patrick, I did see what you see, so I just re-selected Auto Connect under the Radios menu and now it auto connects again.
I do seem to be able to export and import, but I had to fill in the file name.
Thanks for the suggestions. The file name fill worked. But I am still having problems with auto connect. Even though I select auto connect, it still will not auto connect. I have tried deleting and reinstalling. Select auto connect then shut down app and restart it. Still no auto connect. Never had this problem with FRStacks before. Will contact the people responsible for the app.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
