FRSacks not auto connecting anymore
Since the last two upgrades of FRStacks3 it no longer does an auto connects. I have to select a radio then connect. Even when auto connect is selected, it still will not auto connect. In the past it would do the auto connect reliably. Another issue I noticed is that I cannot export configuration setting to a file. Any one else seeing these issues.
Hi Patrick, I did see what you see, so I just re-selected Auto Connect under the Radios menu and now it auto connects again.
I do seem to be able to export and import, but I had to fill in the file name.
Thanks for the suggestions. The file name fill worked. But I am still having problems with auto connect. Even though I select auto connect, it still will not auto connect. I have tried deleting and reinstalling. Select auto connect then shut down app and restart it. Still no auto connect. Never had this problem with FRStacks before. Will contact the people responsible for the app.
- 113 SmartSDR+
- 920 Genius Products
