How to work in SmartSdr with N1MM in Split
Cees
I'm unable to work in Split. Below you can see the two setting windows for working in split mode. With my keyer it works fine, but if I want to send with N1MM then the Up window immediately goes TX off.
This is after an attempt to send with N1MM:
Below my Radio Setup
Who can help me solve this problem?
Regards and 73 Cees, PA3CVI
Problem solved, wrong setting. 73, PA3CVI
[{"insert":"What was the wrong setting, and what was the correct setting for all us out here experiencing the same problem? Please share the answer. Thanks in advance.\n"}]0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
