SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
How to work in SmartSdr with N1MM in Split
I'm unable to work in Split. Below you can see the two setting windows for working in split mode. With my keyer it works fine, but if I want to send with N1MM then the Up window immediately goes TX off.
This is after an attempt to send with N1MM:
Below my Radio Setup
Who can help me solve this problem?
Regards and 73 Cees, PA3CVI
Problem solved, wrong setting. 73, PA3CVI
[{"insert":"What was the wrong setting, and what was the correct setting for all us out here experiencing the same problem? Please share the answer. Thanks in advance.\n"}]0
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
