winkey emulation sounds terribly
CW sounds bad both on N1MM and DXLog here is a sound clip
is this a known issue ?
/Tore
  • Bob K8RC
    Bob K8RC Member ✭✭✭
    Who wants to open a Zip file from unfamiliar source?
  • Tore
    Tore Member ✭✭
    edited May 2021
    true but it did not let me attach it otherwise so just trust me it sounds bad
  • Erik Carling EI4KF
    edited May 2021
    Is it not just a case of your break-in delay being too short? It sounds like the characters are truncated. Maybe , I don't know - just an idea.
  • Al K0VM
    Al K0VM Member ✭✭✭
    What version of SSDR are you using ?
  • Tore
    Tore Member ✭✭
    I am using the latest version of v3. Strangely enogough after a reboot of the radio it became much better indeed very strange. I dont think the delay is to short (200 ms) it sounds to be that sometimes character are truncated sometimes to long a dot for example can become a dash timing sounds totally off
    OK at 200ms I have the same effect. I had to increase delay. But of course your issue may be something else entirely.
