SmartSDR V2.7.3 Unhandled Error
I am getting a Unhandled Error in SmartSDR 2.7.3 when ever I select Memory.... from the settings tab. Also when I select Spots... or Network... there is nothing shown except a box with a X in it. It is not causing a problem as long as I don't click on "Memory", that causes SmartSDR to crash.Network.... Has anyone else run into this issue?
When I select Memory... from Settings tab.
when I select Spots from Settings tab
When I select Network from Settings tab
Have a look at paragraph 3... Reset/cold boot may help.
Ross,
This may be a client configuration issue not fixed by resetting or rebooting the radio. It may run correctly on another PC.
On the problem PC, close SSDR, navigate to %appdata% > roaming > FlexRadio Systems and rename the SSDR.settings file.
A new SSDR.setting file will be rebuilt when you restart SSDR. You will need to reselect your global profile and resize you window to fit your needs.
AL, K0VM
3 -
Thanks Al, that fixed the issue!!!
I second the thanks to Al... my 6700 (SSDR 2.7.6) had the same problem and was doing the same thing. Now, all is back to normal, at least until the next Windoze update. :)
Thank you all for your replies. I will give this fix a try once my radios are back up after a smartsdr update matter is resolved.
Craig, w7phg
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 247 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
