S7 solid line noise. suggestions.
Good morning all. I run a 6600M on a carolina windom antenna at about 34 feet. I have read the manual a lot but still can't mitigate this noise. I have torid cores on every cable, some have two. I have lowered and raised the AGC-T. Have tried noise reduction button on the radio. Take it down quite a bit but also takes the signal down. Kind of at my wits end with this. Anyone have a magic fix for this???
KB4OIF
John
It is always best to eliminate the noise at its source. Have you tried running your radio off of a battery and flipping the breakers off? Can you describe the noise. 60Hz buzz, always on no matter the weather, second to second variations or not, etc.
Jeff W4DD
Frying bacon noise. It's S7 on 40 meters. S4 on 20, S3 on 17, S3 on 15, S2.5 on 12, S2 on 10, and S1 on 6. Have to figured out how to run it off a battery. Have not done the breaker thing. Will do that soon as I get back from the dog groomers.
KB4OIF
John
FYI..... I had a broadband noise that was caused by the laptop charger that was running SSDR. It was a nice Dell charger that just started spraying noise all the sudden. I had a spare and problem, for me, was solved.
I'm a fan of turning the whole house off at the mains breakers and running off battery as an initial debugging technique also. Then I use an AM aircraft hand held receiver to go around the house and find the source. Good licj with it.0
I have a similar situation, Carolina Windom in attic at about 34 feet and a 6600.
I have noise spikes every 30 KHz on all bands. I have Ethernet wiring in the house with a router and a couple of switches. If I shut the network stuff off the noise is gone. Ferrite on every cable no help.
TNF is a big help.
Roger
Roger,
Generally I have not found the Ethernet cables to be much of a problem, especially if using Cat 5e or better. However, the SMPS (power supplies) for the router and cable modem can be very noisy. I changed out my cable modem ps to a linear type as it was a commonly available 12V type. For the ps for the router (19VDC), I used snap on ferrites at each end of the SMPS power line that connects to the router. I plug both of these into a Trip Lite Isobar. These things reduced my 80M noise level by 2 S units. It's been a while since I did a ckt breaker test so I need to do that also. I generally like to do that about once a year as each year more and more electronic devices make there way into the QTH.
de Jeff, W4DD
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
