Can I use the Reverse Beacon Network as a spot source in Slice Master for Smart SDR?
This is what the RBN site says:
RBN spots are available via telnet protocol at the following addresses:
telnet.reversebeacon.net port 7000, for CW and RTTY spots
telnet.reversebeacon.net port 7001, for FT8 spots
These nodes run stripped down relay servers specifically designed for maximum throughput. They have no filtering features..
Our intent is that "retail" DX clusters should connect via telnet to one these nodes, and that end-users should connect to the "retail" nodes.
What are the "retail" DX clusters they refer to? Which ones are good and I might want to use?
Thanks for your help.
Bob, WK2Y
Hi Bob, I just use the spots from my N3JFP logger. I get the RBN spots plus whatever else is out there. I haven't looked too closely at the sources, but since my SSDR screen fills pretty quickly with spots, I haven't bothered to seek out more.
Thanks, I look into that. I think I found what I want, a program called CC Cluster I just have to figure out how to send the spots to Slice Master or straight to SmartSDR. It's a pretty powerful little program
Thanks again.
Bob, WK2Y
According to the Slice Master documentation for the spot sources field:
"So, telnet://XXXX@ve7cc.net will get you started (replace XXXX with your call sign. I also use telnet://k1dbo@daphne:7301?sh/dx to connect to a CC User instance running on a near by computer."
The first statement works but I don't get the "daphne" in the second and Slice Master says it's an invalid spot source. None the less, the first statement does seem to reflecting the filters I have specified in CC Cluster.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
