Can I use the Reverse Beacon Network as a spot source in Slice Master for Smart SDR?
This is what the RBN site says:
RBN spots are available via telnet protocol at the following addresses:
telnet.reversebeacon.net port 7000, for CW and RTTY spots
telnet.reversebeacon.net port 7001, for FT8 spots
These nodes run stripped down relay servers specifically designed for maximum throughput. They have no filtering features..
Our intent is that "retail" DX clusters should connect via telnet to one these nodes, and that end-users should connect to the "retail" nodes.
What are the "retail" DX clusters they refer to? Which ones are good and I might want to use?
Thanks for your help.
Bob, WK2Y
Hi Bob, I just use the spots from my N3JFP logger. I get the RBN spots plus whatever else is out there. I haven't looked too closely at the sources, but since my SSDR screen fills pretty quickly with spots, I haven't bothered to seek out more.
Thanks, I look into that. I think I found what I want, a program called CC Cluster I just have to figure out how to send the spots to Slice Master or straight to SmartSDR. It's a pretty powerful little program
Thanks again.
Bob, WK2Y
According to the Slice Master documentation for the spot sources field:
"So, telnet://XXXX@ve7cc.net will get you started (replace XXXX with your call sign. I also use telnet://k1dbo@daphne:7301?sh/dx to connect to a CC User instance running on a near by computer."
The first statement works but I don't get the "daphne" in the second and Slice Master says it's an invalid spot source. None the less, the first statement does seem to reflecting the filters I have specified in CC Cluster.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
