SmartSDR v3.2.34 installed without issue
Good Morning all,
I just installed v3.2.34 on my Win10 Pro desktop. It updated the radio without any issues. I just followed the pdf.
I updated my Maestro without any issues as well.
I want to Thank the Flex team for their fast response on fixing the issues discovered in the last release.
Brent VA7BNB
Victoria BC
Welcome!
  • Member ✭✭✭✭
    Same here. 6600M and NUC with Windows 10. Whole upgrade perhaps 20 minutes.
  • Member ✭✭✭
    no issues - 20-30 minutes
  • Member, Super Elmer Moderator
    Good upgrade for me too, no issues at all. Also tested a downgrade to 2.7.3 and back to 3.2.34. All worked perfectly.
  • Member ✭✭✭
    Installed without the issue as well. The only thing noticed this morning Maestro was disconnected.
    Everything worked last night after upgrade, need more time to monitor stability...
  • Member ✭✭
    Same here, no issues at all.... Good work Flex.....
    Charlie, WA3UTC
  • Member ✭✭
    Upgrade went fine in about 5 minutes. I didn't have many profiles so needed to recreate a couple, The only problem I had was that I didn't setup TX1 for amp keying at first and the amp didn't work when I first tried it, my bad.
  • Member ✭✭✭
    I have mentioned before the Windows blue screen errors when loading new version of SmartSDR. I takes a couple of computer restarts before the blue screen stops and then I can use SmartSDR without future issues. This issue has happened on every version update since V3 was released and on several computers. I did not bother trying to troubleshoot and submit a tech support ticket since it would clear and not reappear after a few reboots.
    I must say that with this SmartSDR install of V3.2.34 the blue screen issue did not occur. The first time in a long time. Also, I installed it on 5 different computers and no blue screen error. Whatever, you did in this release seems to have fixed the problem. Nothing else has changed on any of the computers....no new software and no Windows updates since the V3.2.31 update a month ago.
    John K3MA
  • Member ✭✭
    My install also went very well. no issues or delays.
    Great job
    Paul
    KR5OG
  • Member ✭✭
    @Brent, VA7BNB , Did you have big issues with v3.2.1? I did and after getting downrev'd back to v3.1 (thx Flex Support) I am afraid to even attempt the newer v3.2.34.
    Does anyone that had issues with the original v3.2.1 update have those issues carry over to v3.2.34?
    Pat W5WTH
  • Member ✭✭
    Sorry for the late reply. Camping and reading the manual. 😀
    I haven't had any issues with updating my 6400 or my Maestro. I got confused and downgraded the radio and the Maestro, but that was my poor eyes!
    ...Brent...
