ALC Problem
I have flex 6400 and als-600 amp, My alc line was connected between rig and amp with old 3.1.12 version with out any problem , but now upgrade to 3.2.31, now I need to disconnect alc line because once a wile no output on flex 6400, Hope new version will cored this problem 73' Dan VE2ZC.
Hi Mike
I did open support case, received call from Dan and was no solution with my alc problem, hi did take notes on my problem and was hopping that next update will take care of this.
Thanks Mike
Have a nice day
Dan VE2ZC 73'
We haven't made any changes in the ALC code for a LONG time to the best of my knowledge. You may also want to backup your profiles and then do a radio reset and reload your profiles.
If you think you have an issue, you may wish to open a support case so we can diagnose it further if the problem still exists after that.
Hi Mike
I reset radio like you suggest and still have same problem, was just on 20M and after 1 minute I have no more power output from my rig, soon disconnect alc line everything get back to normal. I never have any problem with version 3.1.12 something was change.
Hope they will resolve this problem.
My ticket number is 43025
Thanks Mike for trying to solve my problem.
Dan
VE2ZC 73'
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
