Profiles
I have several Global Profiles set up to operate FT8 and FT4 at the same time on the same band. On some bands this meant that I had two panadapters set up in the main SSDR window. All was working well until recently when I popped one panadpter out of the main window and set it up on another monitor.
Now I cannot get the Profles to open with both panadpters in the main window. In fact if I try to open a second panadpter in any profile even if,it never had a second panadpter before the panadpter opens on the second monitor.
I have tried popping the panadpter back into the SSDR window and saving the profile. That doesn't work, the next time I open the profile the panadpter is on the second monitor. I have deleted the profile and then tried to set up a new one. When I try to set up the second profile it opens up on the second monitor.
I have 6600 running V 2.6.2 SSDR on Windows 7 Pro 64 bit.
I have run out of things to try.
Paul W5PF
You might try the following:
- Pop the second panadapter Window back into the main SSDR window frame.
- Close the SSDR App
- Re-launch SSDR and confirm that it launches with both panadapter windows in a single window frame
- Save your profile for the two panadapter config
- Close one of the two panadapters
- Re-load your profile and confirm both panadapters open in a single application window frame
Ted WR4T
Ted, thanks.
I didn't try the exact procedure you suggested, but I finally go the panadapters to open correctly. I opened a third panadapter which opened in the SSDR window, then popped the wayward panadapter back into SSDR and switched to another profile. When I reopened the profile that I was having trouble with it opened correctly. Everything seems to be correctly now.
Paul W5PF
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
