I would like to ORDER a cable from a Heil Pro 7 to a flex 6600 ana a cable (mike) from a PR 781 mike
How do ai make these orders? Tom Vickers N4TV 901-854-9912
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    Did you want to connect your 781 to the balanced audio input jack or the pseudo-balanced microphone input jack?
  • tvicker1
    tvicker1 Member
    The balanced audio input jack
    edited May 2021
    Flex offers a 3 pin XLR balanced line-in audio cable for Flex 6600 for $23.99.
    The 3 pin XLR end fits the 781 and the 3 conductor 1/4 inch end fits the balanced audio input jack on the 6600. I use a foot switch for PTT control.
  • tvicker1
    tvicker1 Member
    Yes, will this work with both the mike cable and the Headset? Do I need one or two?
  • K0FLY
    K0FLY Member ✭✭✭
    You don't need a special cable for the Pro 7 to Flex 6600.
    The Heil Pro 7 headset is supplied with two cables (one is coiled and the other is straight). Each cable has a 1/8 inch TRS connector which interfaces with the headphone output on the 6600 and a 1/8 inch TS mic connector (two conductor tip sleeve) which will plug into the MIC input on the 6600. Select the mic input in SSDR, it works for me. I have a mix 31 fairrite clamp on installed on the cable as insurance against RFI in the mic.
    My 6600 sits where the stock Pro7 cable is a little short and I wanted the cable to be routed under the operating table, I used two 6 foot stereo extension cables to extend the Pro 7 wiring. After 2 years no trouble doing this.
    I use a Behringer 8500 on the 6600 balanced input and use mic profiles to select which mic input I use.
    Gayle K0FLY
  • tvicker1
    tvicker1 Member
    Thank you for the help Gayle, it is very greatly appreciated..
