I would like to ORDER a cable from a Heil Pro 7 to a flex 6600 ana a cable (mike) from a PR 781 mike
Did you want to connect your 781 to the balanced audio input jack or the pseudo-balanced microphone input jack?
The balanced audio input jack0
Flex offers a 3 pin XLR balanced line-in audio cable for Flex 6600 for $23.99.
The 3 pin XLR end fits the 781 and the 3 conductor 1/4 inch end fits the balanced audio input jack on the 6600. I use a foot switch for PTT control.
Yes, will this work with both the mike cable and the Headset? Do I need one or two?0
You don't need a special cable for the Pro 7 to Flex 6600.
The Heil Pro 7 headset is supplied with two cables (one is coiled and the other is straight). Each cable has a 1/8 inch TRS connector which interfaces with the headphone output on the 6600 and a 1/8 inch TS mic connector (two conductor tip sleeve) which will plug into the MIC input on the 6600. Select the mic input in SSDR, it works for me. I have a mix 31 fairrite clamp on installed on the cable as insurance against RFI in the mic.
My 6600 sits where the stock Pro7 cable is a little short and I wanted the cable to be routed under the operating table, I used two 6 foot stereo extension cables to extend the Pro 7 wiring. After 2 years no trouble doing this.
I use a Behringer 8500 on the 6600 balanced input and use mic profiles to select which mic input I use.
Gayle K0FLY
Thank you for the help Gayle, it is very greatly appreciated..0
- 685 The Flea Market
