Audio Issue in my new 6600M
Noise start when my radio start up
Sounds like static discharge inclusive when moving my dial too ..this radio only have few week , I reset the radio few time but the noise continue in CW ,SSb and digital mode too.
Any solution?
Just for grins if you have edited and saved profiles export them in SmartSDR then do a hard factory reset.
It may have had some weird data in it when it shipped and hard resetting it will let you start with a clean slate so to speak.
Then see if it sounds better, then you can re-import your profiles being careful NOT to IMPORT your preferences this should get you almost back to where you began without the noise in your audio.
I get a pop when starting the radio. It does not persist or happen after I get things up and running though.
I have SmartSDR for mac. On startup, I hear static when the sound is muted, I just enable sound and then mute sound and the static goes away until the next restart.0
this static is all the time even more so when I move the dial or move the volume of the radio ... and at all times that I am receiving ...0
I have not done profiles yet, I have reset the factory several times, I have installed the software 2 times as well and it continues even more when I move the radio buttons, it is as if it were electric discharge, it is very annoying.0
I have the example Audio but I need the email for sent to you and listen the issue....0
if you have done all that already you may want to send in a help desk ticket,
I do have a question do you have ANY of your DSP filtering on?
WNB, NR, NB or ANF If so try turning them off and give a listen, These require very low settings so you don't get static on strong stations.
You can send me a screen grab of the spectrum screen and a audio clip if you like at wx7y at arrl.net
maybe I can give you an idea
ok i sent the audio ... ....yes all is off all filter....i put the ticket today ...anyway my audio go via you email...tnx
Got them and listened to them and I know when my FLEX 6700 and / or 6600M does that I have to do a hard reset and the radio is back working good for a month or so.
I know you have done that already so just have to wait for service to get back to you.
sorry that didn't help
If I have done it on several occasions, I hope that flex can solve it since I just bought this 6600M and another one that is on the way in several weeks and I would not like to have this issue. I thank you for your support and I let you know what flex solves ... thank you very much for your help.
If you wish, you an add a video of the issue to your posts here.
ok i try the tranfer the audio....here..ok Mike i try but the audio no pass here I need the tranfer in other format...but sent me you email for sent the audio...ok my personal email is ....monvaz2008@gmail.com
Ok mike i sent the audio via you email....tnx
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 762 Peripherals & Station Integration
- 982 Third-Party Software
