Issue with iPhone not connecting
Mark DePaepe
Member ✭
[{"insert":"Hello All, \nI have had problems with my iPhone X not connecting to the radio via the phone carrier service. I had configured a reserved IP for the radio and set up port forwarding. Neither of those changes made any difference. The phone app connected to smart link, showed my radio available but did not actually connect to the radio. Uninstalling the app and reinstalling the app corrected the problem. \n"}]
Mark,
Did you set the port forwarding in the router? Easiest to check using SmartSDR -> SmartLink, when you run the test you should get a green light, to let you know that you are forwarding through ports 4993 and 4994 on your router, make sure you hit the Save when you have successfully got ports forwarding
Dudley / WA5QPZ
Hi Dudley,
I had told Mark to do the uninstall and reinstall. A good friend also had the same issue with his iPad Pro. Only way to resolve it was to uninstall the app and download & install it from the app store.
Not sure why, but it fixed two issues that were not router/port forwarding related.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
