Problem with Latest 64K Windows download of WSJT-X Keying SmartSDR on band change
This just started when I upgraded to the new version of WSJT-X V2.3.1 0e70024, and what is happening ONLY when changing bands the WSJT-X Transmit won't transmit BUT the WSJT-X, TUNE button works fine, If I just go into settings CHANGE nothing and just click save it transmits JUST fine until I change bands again.
I am using the Cat control IP keying on 127.0.0.1:60001 as always.
I'm sure this is a BUG in this version of WSJT-X V2.3.1 and I'll probably down grade to a older version and try it.
I am really not asking for advice but just to see if ANYONE else is seeing this JUST on the NEWER version.
more updates, Went to WSJT-X 2.4 RC4 version and all problems went away and then went back to version 2.2 WSJT-X and it also works normally so at least at my station the only version that causes this is WSJT-X V2.3.1 0e70024 that does this on band changes that I tested.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
