new software version 3.2
anybody having with the radio having to be reset; got mine back from flex with a new sdr card and just the other day had to reset it twice to get it back; was recommended to also reset the display which i have not done yet but had flickering on the left side of the display; tnx for any info
6400 here with existing SD card. Ver 3.2 has been working fine and no hardware issues. Have not had to reset radio.
Can you provide a bit more details as reset is a bit of a generalistic term. Did you do a database reset? What does 'get it back' mean?
Sorry, it also helps which model of radio you are using.
A video of what you are seeing is very helpful to help diagnose your issues.
I recently needed to replace my SD Card.
The replacement card was shipped with v3.2.14 fimrware.
Since I was running the latest v3.2.31 Smart SDR, I had to first downgrade to v3.2.14 to test the card, then upgrade the firmware up to v3.2.31. Then, all was good.
This came as not surprise as Tim's instructions clearly pointed out the steps.
Perhaps your radio came back with the earlier 3.2.31 any you were running a different version Smart SDR?
Alan
Wa9WUD
Tnx so far so good; also sometimes I have to reboot my maestro when I’m in manhattan ; it doesn’t recognize the fhm-3 mike either under default setting or under the fhm-3 clicked on ! I have to turn on and off the maestro; also obviously had to update the maestro to latest software but it did DO THIS even under older versions
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
