PGXL Output Power Controls on 30M and 60M
Does the PGXL have special power output controls of some kind on the 30M and 60M bands which have unique power output rules for N. America.
    No
    It is up to the operator to ensure they operate their radio to match the terms of their license.
    This hobby, unlike others, requires you to be well aware of where you are transmitting and how much RF power you are using. That is why you are tested in the beginning.
  • Mike_WB8CXO
    Mike_WB8CXO Member ✭✭
    All knobs to the right!
  • M0GZR
    M0GZR Member ✭✭
    It will be useful if the TX Band settings will fork similar to the Max power settings, or even better if we can set up the max power from the PA per band while is integrated with the SmartSDR
  • WX7Y
    WX7Y Member ✭✭✭✭
    you can do that now, click on settings then click on TX Band settings and simply set it there for each band.
    Not sure if this is what you want but if not FRStack will do power drive settings between Amp Drive or Barefoot.
  • M0GZR
    M0GZR Member ✭✭
    edited April 2021
    Hi Bret
    Thanks for your comment
    That solution almost is what I want, but the settings are not persistent, as long as you move the power slider on the main smart SDR screen above the max tx power you have selected for that particular band, that value on TX Band will get overwritten
    If the TX per band will work the same way as the total output power on the SmartSDR settings but per each band will be brilliant
    73'
    Marcin M0GZR
