Conections Yaesu M-100
LU5FC
Can someone help me connect the Yaesu M-100 microphone to the Flex 6400M?
remember that the Yaesu mics have both 8pin foster and RJ45 built in.0
Ciao Larry, se vuoi sul mio qrz.com c'è qualche schema di applicazione sui microfoni per la serie 6000 e Maestro, forse può aiutarti, 73 Per
Hi Larry, if you want on my qrz.com there is some application scheme on microphones for 6000 series and Maestro, maybe it can help you, 73 For
Scusa ma era per LU5FC 730
Thanks. Larry. But see: "....This adapter will not work with a Condenser microphones or microphones that have a Up/Down button as there is no Bias voltage available. It will work with a Microphone with a Dynamic element. ..."0
Sorry, I thought you were refering to a MD-100.0
ok. thanks0
Grazie Ho visto il tuo QRZ.COM. Molto interessante proverò a collegare il mio SM-8 da Icom al flex secondo lo schema che hai lì. 73 Grazie. Jesus LU5FC
Ok Jesus, 730
[{"insert":"yaesu md 100 direkt am originalen Handmikrofon-Kabel rj 45 angeschlossen, am 6600M, funktioniert nur PTT, kein Mikrofon Eingang, gleiches Mikrofon und Kabel funktioniert am 6400 mit yaesu 100 einwandfrei, die originalen Handmikrofone funktionieren beim 6600M und 6400. wie kan das?\n"}] DK1EHK 730
[{"insert":"you need connect separate cable to accessory rear the 6400 panel , m100 need 5volt , the rest is same the fhm3 , ciao \n"}]0
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
