Longer cable to router
Best Answers
you should use CAT6 or better and up to 50m is no problem
73 Chris DL5NAM
It is standard. As Chris stated, you can use normal but high quality CAT6. My club station has 180ft buried with no issues.
Terry yes you can... the brand name Cable Matters has been recommended in the past. You want to make sure you have a good quality cable.
Ronald
Thanks for your suggestions, so it's a standard cable not reworked by flex with different plug wiring?0
Terry:
Standard cable. Thanks for your work with LOG4OM.
Gayle K0FLY
Be careful not to be resonant at RF. Avoid 1/4 wavelength or multiples.
Some folks swear by shielded cable (perhaps with shield cut at one end to avoid ground loops). Other folks say not to worry.
Cat 5/ Cat6? My attitude: try it and see how it goes. But Cat 6 won't hurt.
I've had some troubles with 1 Gb connections (with Maestro) that went away when I used a 100 Mb router. Ymmv!
73 Martin AA6E
Weird enough, but I also replaced a 1gb switch with a repurposed router (WiFi off) 100mb ports, and the network dropping the flex went away. Something internal in the way the data stream is handled, I guess.
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
