Problems with CAT
See pic, this happends when trying to start up. And it happends on both my computers..
  • Al K0VM
    Al K0VM Member ✭✭✭
    Pic was to small for me to see.
    AL, K0VM
  • Erik Carling EI4KF
    Just click on it to see the original size. To fix, I believe you should use the specified Flex procedure to uninstall and reinstall SSDR. This was Mike VA3MW's solution to this problem that was earlier reported on the Forum and it worked for the user concerned.
  • David Decoons, wo2x
    what model radio? I have seen that if an M model is upgraded to 3.2 but the PC SmartSDR was not upgraded.
    If you still have problems then open Help Desk ticket.
    We need a bit more of the station setup
    Model
    Version of SmartSDR you are trying to run (the error references 3.1.12)
    Did you install 3.2 and then try to roll back to 3.1.12?
    Anything else?
