Problems with CAT
Jonas
Pic was to small for me to see.
AL, K0VM
Just click on it to see the original size. To fix, I believe you should use the specified Flex procedure to uninstall and reinstall SSDR. This was Mike VA3MW's solution to this problem that was earlier reported on the Forum and it worked for the user concerned.
what model radio? I have seen that if an M model is upgraded to 3.2 but the PC SmartSDR was not upgraded.
If you still have problems then open Help Desk ticket.
We need a bit more of the station setup
Model
Version of SmartSDR you are trying to run (the error references 3.1.12)
Did you install 3.2 and then try to roll back to 3.1.12?
Anything else?
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
