N1MM and CW Skimmer setup assistance 2021
Heys community. I am looking for help with setting up N1MM and CW skimmer for the modern versions of Smart SDR. I searched the community but all the ones I can find are broken links, outdated or a couple that just don't work. I am running Smart SDR 3.1.12
Any help or resources would be greatly appreciated.
Scott
There is a great video on You Tube,
I thought this had setup instructions but it appears to be just demo.
Paul
kr5og
I found this video which is good but I am having a problem. I follow it to a T but when I get to 4:03 is the issue. Under Dax control my IQ Stream will not display streaming, it displays "no pan adapter"
You missed the step where you assign the IQ stream to a panadapter.
DAX IQ Channel selection
Using SliceMaster, I finally have CWSkimmer working and, most importantly, starting reliably for me. I thought I would put in writing some of the items I overlooked or was not aware of in the hopes that I can help someone else avoid some of the confusion I went through. I’m sure if I had taken the time to RTFM or watch some videos in detail, I could have avoided a few headaches I mention below, but I’m a ham. 😉 If you have corrections, work arounds, explanations, or additions to my notes, please don’t hesitate to mention them.
- Not only do you have to select a DAXIQ channel on the slice, but you also must make sure the same channel is enabled in the DAX control panel(Duh).
- Make sure that the DAX control panel is tracking the frequency shown in the slice. I have had instances where the control panel button for the channel is blue and says streaming, but the slice frequency is not being followed. The best solution I have found is to boot my PC.
- The only sampling rate that seems to result in good decodes is 48000. That has to match the sampling rate in Settings, Radio(Duh).
- Under view, open the IQ balance and check Correct Balance. I think this is helping, but feel free to tell me if I’m wrong.
- In Settings, Audio, the sound card driver I am using is MME.
- In Settings, Radio, the hardware type is SofRock.
- In Settings, Radio, The LO Frequency is 7062500
- I try and load CWSkimmer first after starting SliceMaster and after a PC restart.
Bob, WK2Y
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
