Virtual Serial Port Com4 not present
Cees
Hi members after a reinstallation, COM 4 has disappeared and is therefore not selectable.
What can I do to fix that.
Cees , PA3CVI
Solved:
Found in FLEX community:
- Shut down SmartSDR CAT and SmartSDR (for that matter, close app open programs)
- Using Windows Explorer, navigate to where the installer is located
- The path is \Program Files\FlexRadio Systems\FlexVSP
- In that folder is the file: FlexVSPInstaller_xx.msi
- (where "xx" is 32 or 64 depending if your operating systems is a 32 or 64 bit.)
- Right click on it to get the context menu
- Select the Repair option
- Answer YES to any prompt and then wait while the repair executes. It may take a little while.
- When prompted to reboot your PC, select YES and reboot.
Thanks Tim Ellison
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
